Old 09-18-2002, 08:59 PM
Whaler Whaler is offline
Default E-brake question and grommet question
Hi
I have my lokar handle installed now. I will be drilling the hole to pass the 2 cables thru to the wheels next....Is there an oval shaped grommet made? I would like to drill one hole and pass them thru in the oval shaped grommet one on top of the other.
If not then its two holes and grommets.
Secondly I have deville rear calipers, they have a large return spring on them where the brake cable will attach. This spring is about half as long as the spring on the LOKAR cables. The lokar springs easily fit inside the deville springs, but they are twice as long.....should I cut them to match in length or discard the lokar springs entirely and rely only on the seville oem return springs?
They are pulled in from the rear of the car and located at the top, fairly similar to this pic
Tim
