Old 09-19-2002, 08:19 PM
Jeff Frigo's Avatar
Jeff Frigo Jeff Frigo is offline
Cobra Make, Engine: ERA 454 S.O.
Paul:
You are using the wrong lube. All modern manual transmissions use ATF. You probably ruined the syncros, that's why second gear grinds.
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
