Old 09-20-2002, 12:06 PM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
I use the Carrera setup on the Cobras I build. The 375lb spring works great. The Carrera setup gives a great ride. You will need to get a longer shock than the Mustang II uses. The tower on the Classic is taller than stock. The shock I use is a #3257SU058. The spring is an 8MB375. I haven't seen a setup that will work with the stock lower arm unless it is modified. I would double check with them and find out for sure it will work.
Don
