Old 09-20-2002, 12:48 PM
Jeb's Avatar
Jeb Jeb is offline
I'm a bonehead!
What is your cooling setup?
Radiator (aluminum? # of cores?)
Fans (electric only, puller, pusher?)
Shroud?
The moving coolant temp seems right, the idling temp seems warm. What is your timing at idle in traffic? How bored out was your block, do you have a sonic mapping of the cylinders (thin spots transmitting heat)?
Oil pressure seems in the right range, though again, more info: what sort of pump are you running?
They serve also who stand and wait
