Ours fit just fine in a 94" WB car!
Our next one will be a 90" WB.
Tell Randy if I can be of any help to just holler! Right now with all the improvements we finally got through Dodge the only real problems are the exhaust and gauges.
If he doesn't already know, tell him to make sure he does NOT leave out the battery temperature sender! (If you leave it out the alternator will not charge! If you wire up an aftermarket alternator the PCM wont read the voltage and , IF it runs it wont run worth a poop! "Battery Temperature Sensor". Who would have thunk it!
DV.. Good luck Randy! I see a great "grudge match" at the DVSF III.
