Mike-
Are you going to use everything that you listed?
I ask because I don't think I would use that heavy old crank or those rods. I would also get either Shelby or Edelbrock aluminum heads - is the flywheel aluminum? If not I wouldn't use it either. I am partial to the Aviaid
oil pans so the
oil pan would go too. Water pump looks like a heavy one too - I would get an aluminum one.
What I am saying is this - is this engine what you would have built given a blank sheet of paper? If it is, great! In that case I would say it may be worth six to eight thousand?
I don't see much reason to use original old expensive used up parts if you are going to build a motor - restoring an old original car is another thing.
Just my opinion!!
Pat
PS - Did you sell your 428 yet?
