Old 09-24-2002, 09:13 AM
jams's Avatar
jams jams is offline
Cobra Make, Engine: B & B
Default Bowtie Timing/distributor Tech Question
Hi,
Here is the situation:
I need to adjust my timing and turn the distributor counterclockwise (I don't know if that is called advance or retard) The problem is the vacuum advance portion of the distributor is already making contact with the intake manifold so I have no room to move. I know I need to take the distributor out and rotate the rotor but that is as much as I know and I don't like experimenting with timing issues.
Thanks for your help.
Jim
Just enough knowledge to build a cobra and be dangerous...
You can observe a lot from just watching.
