Thread: FE numbers...
Old 09-24-2002, 03:20 PM
Ron61's Avatar
Ron61 Ron61 is offline
Default Re FE numbers
Mike,
I have a 1969 Cobra Jet engine reference manual. The head numbers should be cast in raised numbers between the center two spark plugs. According to my manual C8OEN is the number for the regular 428 CJ. Mine is the 428 SCJ and my head #s are different as they are 427 medium riser heads that came on it from the factory. Also under the valve covers you should have the same date code as you found on the block. It is laid out as I showed in an earlier post to this.
Ron61
Ron Widener
