C29,
I just got through foolin' with my carb, and noticed that there are 3 holes in the crossshaft arm on the pedal side, and either 2 or 3 holes in the crossshaft arm on the carb side. You will get max travel using the hole closest to the shaft on the pedal side, and the hole furthest from the shaft on the carb side. You also want to shorten the pedal link until you get enough pedal travel to open the carb all the way, but don't leave very much air under the pedal at WOT, or you may bend something when you get a little too "enthusiastic". Did I cut my pedal link? I don't remember, but I might have. I have a std Holley, no probs with WOT. I have the carb link bolted to the carb arm through a 1/4" factory hole in the arm.
Ken
