Kris-
410's and 428's are externally balanced, 390 and 427 engines are internally balanced.
I used the next step up from stock clutch in ERA 535 and was fine - easy pedal etc.
When I put it together originally I got a clutch set up from Summit that the bolt holes wouldn't match the flywheel - maybe you have the same problem?
Pat
