Thread: Ignition Coil
Old 09-29-2002, 09:29 PM
Whaler Whaler is offline
I went and had a look at the MSD site...looks like I may have to move mine upright as it as the MSD blaster2 in chrome finish
"MSD Blaster Coils
If you are looking to upgrade your stock coil, or want to compliment the performance of your MSD Blaster Ignition, MSD 5, 6 or 7, the Blaster Coil line is the right choice. All of the Blaster Coils are designed for improved spark output!
Special 100:1 windings are used to provide maximum build-up of voltage! These windings are held secure and kept cool in an oil filled metal canister. The tower assembly is molded of durable alkyd material due to its high dielectric characteristics while wide spaced brass primary terminals prevent the possibility of spark.
There are several versions of the Blaster Coil available. All of them have the same internal specifications, but have different housings or components. Each Blaster Coil can be used with a stock ignition, Blaster Ignition, MSD 5, 6 or 7 Ignition Control. Most late model vehicles with electronic ignitions do not require a ballast resistor, check your ignition and manufacturers specifications to determine if a ballast is required in your application.'
Where as this guy is filled or encased in epoxy
Blaster High Vibration Coil, PN 8222
For circle track, off road and other severe duty racing applications, this is the coil! The windings of the High Vibration Coil are completely encased in a premium epoxy making it impossible for vibration to affect the windings. This assembly is housed in a unique alkyd molded shell which provides high dielectric characteristics plus a very durable shell. Brass primary terminals ensure full voltage delivery and are spaced far apart to eliminate the chance of spark arc-over. The High Vibration Coil can be mounted in any position and can be used with a standard canister coil mount.
Blaster High Vibration Coil - PN 8222"
