Old 09-30-2002, 06:24 AM
Roscoe's Avatar
Roscoe Roscoe is offline
Ernie was talking about my overheating problem. I originally used a Milodon copper but was not informed of the silicone need and was pushing water into my cylinders. This is before I even installed the body on the car so it was easy to pull the heads.
I now use either Fel Pro or Mr Gasket with the steel ring. No sealer is necessary, just put them on a clean surface. The only thing you can use on it is a bit of adhesive.
If you want a set of Milodon's I've got them hanging on the wall.
Roscoe
Roscoe
