Thread: Heater ByPass
Old 09-30-2002, 11:03 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
You need the regular bypass hose that goes from the pump to the intake. (little 90 degree jobber) The other two you can block off. If you are really cool, you will remove the water pump, pull out the hose nipple and tap it for a pipe plug. Unless you were good enough to get one with threaded fittings already, then pat yourself on the back.
