Thread: Heater ByPass
Old 09-30-2002, 01:05 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
The middle one is for the little bypass jobber, the outer one goes to the heater core. When buying the little bypass hose, there are two that may work, one has same size ends, the other has one end wider than the other. Look at your parts to see which one you will need, the guy at NAPA may try and sell you the wrong one.
