Thread: carpet question
Old 09-30-2002, 04:13 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
The trick to the carpeting is the insulation between the floorboard and carpet. Summit carries double faced aluminum padding, about $40 a roll. Put this in the footwells, and over the trans tunnel foreward of the dash.
Pep Boys, Trak, and the like carry single faced aluminum padding typically used in vans for insulation. Use this from about the dash on back, under the seats, and rear pannel. A piece in each door doesn't hurt either.
While you're in Trak, Pep Boys, there's a 3M adhesive in a spray can specifically for this. Get a case of it.
Properly insulated, your foot boxes won't roast your feet from the hot headers, and the engine heat transmitted through the floorboards should be minimal.
Might take you 3 weekends instead of 1, but you'll thank yourself when the car is on the street.
