Old 09-30-2002, 10:14 PM
Whaler Whaler is offline
What were you presently running for a rad and fan?
Also for the others who have posted why not use a temp controller to do your fan control with a manual overide.....That way you don't have to keep your mind focused on the temp gauge let alone all the others things in busy traffic.
I have a custom 4 core brass 16x20 with a 16 inch puller on a control with bypass. I also have a high volume edelbrock water pump and Marsh underdriven pulley setup. 180 thermostat
I expect it to do the job come this summer when its on the road. Hell I don't know whats next if it didn't .......lol!!
Waterwetter??
Tim
PS Don't forget , shrouding will work against you when the car needs to have free air flow thru the rad. Shrouding at the fan it self sometimes works against you if its too restrictive. Nose shrouding in aluminum is a good idea...How does the rad sit in your car on a slant or straight up and down?
