Old 10-02-2002, 08:27 AM
hardiman hardiman is offline
I steve, I have a Superformance Cobra #1404 that I just drop a 427 SO with webers in. It took a little time, but I have it tuned and running great!!. As far as your Comp 282 cam, you should be fine running it with webers. I am running Comp' 270 cam because I wanted to make sure that there was no intake valve overlap. What are you going to use as a vacuum sorce for your power brakes? I had to use a vacuum pump set up which as easy to mount. I would be gald to help answer any questions that you may have. My work number is 903-597-5700 and home is 903-566-4209. From doing my research, I would not run anymore cam than what you have. The Webers just takes the lope out of the cam. If you try to increase the cam you might get more overlap in your valve timing with will cause back firing back through your webers.
Good Luck!
Dan Hardiman
