Without intake gaskets, when you place the manifold on the motor, how well does it sit? Are the gasket surfaces parallel or perhaps slightly skewed. How well do the intake gaskets match up to the intake and the heads separately? You may need gaskets with different port sizes. If your heads have been angle milled too much you may have problems.
