Hello Whaler,
On both sides of the car the spinner should loosen toward the front of the car and tighten to the rear. Randy R's memory gimmick is " You always want a woman with a tight axx" ie. the spinners tighten to the rear. The safety wire should keep the spinner from turning to the front. If your wheels are not configured this way you may have the left and right adapters on the wrong wheel.
I don't know what safety wire you all are using but I prefer the .041" (1.04mm) thickness. I know that the wire will not hold the spinner on and should only be an indication if they are starting to loosen but, the thicker wire just feels better.
Tony R.
