Is my battery dying?
I'm running an original 289 that has been converted to pertronix electronic ignition. Two days ago I noticed a surging problem, most noticeable from about 4000 rpm on up. When I slowed back down, I noticed the headlights doing a slight dim-bright-dim routine, and the instrument cluster got dim. Is this most likely the battery giving up?
Thanks for your time and advice.
Tim
A good friend will help you move.
A real good friend will help you move a body.
