I have used "Fix a flate" or "Spare tire in a Can" on several of my regualr passenger car tires for years. It is great as sealing pesky small leaks and as a preventative measure. I have been able to seal leaks where the tire was almost flat after one night! Or even PULL out the nail (small hole) AFTER pumping in the Fix A Flat goop and running it a little.
With my Cobra, I hesitate. I often actually change my own tires (I'm old tire man) and the MESS inside the wheel is a real hassle when you have to "clean it up". I DO carry a can of "Fix a Flat" in the trunk (Cobra) as well as a "plug kit" for my "spare tire". There good products, but sure make the inside of your wheel ugly when you have to change tires!
Ernie
