Old 10-04-2002, 12:41 PM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
It may be a bad regulator. They cause the dim, bright, dim routine when going bad. They are pretty easy to bypass and check the alternator output. A battery generally will not cause that type of problem. Grounds sure will though.
Don
