Old 10-04-2002, 04:09 PM
Wisconsin_Snake Wisconsin_Snake is offline
Cobra Make, Engine: Classic Roadsters, 95 EFI 5.0
Default Clutch cable... How????
Ok, I will be setting up the drive train this weekend.
I am getting a ton of parts off a 1984 Mustang (that was totaled with 7000 miles on it, then it sat for 17 years)
What I am confused about is, where is the adjustment part for the clutch cable???
On the 84 Mustang’s clutch pedal bracket, it was there with a automatic adjuster. I see nothing on the CR’s bracket to hook anything up except the end of the cable.
Second question... How do I get the body on the frame (with the firewall in place and the brake booster and master cylinder hooked up?? Or do I put those on after the body has been mounted???
Thanks
