Old 10-05-2002, 12:20 PM
Back in Black's Avatar
Back in Black Back in Black is offline
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Cool The WCC is a (almost) completely redesigned machine
It is designed to have a 50/50 balance with the IRON head BB motors...so the handling is excellent... the WCC has a rigid tubular tig welded spaceframe which makes a big difference by itself...(pic of my finished spaceframe in my photo gallery) The front end has been lowered a bit to improve/increase higher top end speed (aerodynamics)
The real handling variables are:
* Tires...low profile make a BIG (positive) difference in handling, but make the ride more harsh
* The optional WCC suspension upgrade...I have this included...with the optional Carrera coil overs as well...
If you install a SB motor in a WCC, it will be off balance...front end light...which will cause some level of oversteer...I have no idea how much tho
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
