Old 10-05-2002, 07:52 PM
c_forshaw c_forshaw is offline
Default Replacing speedo gear in Toploader
I need to replace the speedo gear in a Toploader. I only see one set screw holding in the cable and gear. The gear will not come out. I jacked up the rearend and moved the wheels, but still would not come out. Should I move the rear wheels with the trans in gear? Any other suggestions?
