I would go solid roller. A roller will allow a steeper ramp which will keep your low end and give you more power up high. You get the benefit of the lift(everywhere) without the penalty of more duration(less low end). With only 10 to 1' compression, I would be careful with going to big if low end is a concern. Also, as stated, easier on the valve train. scott
