10-06-2002, 05:04 PM
VA
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Petek,
The pedal set you have is fine. You can modify the linkages to engage/disengage further down to gain leg room.
I'm trying to fabricate a clutch pedal adapter (piece of 2x4) to put clutch pedal about 2" up for short legged wife to drive car. Then remove so I can drive car.
I used a soldering gun on the carpet to melt seat track indentations for seat tracks to sit in. Also used flat washers to position seats as low into frame as they could go. You could pick up an additional inch by eliminating adjustable seat tracks for fixed seat track brackets.
