Old 10-08-2002, 08:23 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
Another way to check,
Use the adapter hose that came with your compression tester that screws into the sparkplug hole. (or your leakdown tester if you have one) Take the cylinder in question to BDC, pressurize the cylinder with 100psi compressed air, with radiator cap removed, look and listen for air bubbles. Have all the sparkplugs out of adjacent cylinders, if the head gasket blows between two cylinders, you will hear the air coming out the neighboring sparkplug hole. This is similar to a leakdown test, but without recording any numbers to find the "leakdown rate"
