Check your ign switch leads. Some switch have two output leads. One lead that is 'hot' anytime the sw is on. The other is 'hot' when sw is on & not in the start position. The second lead is an acc. lead (radio). You may have hooked up the coil to this lead. You may need to swap leads.
Larry K Hills
