Some late information
Going on four years ago, I replaced my old pipes with a set of the "ceramic mat" sidepipes from Stainless Specialties. Before I sent in my check, I talked with a gentleman from New York who had actually tested both of the Stainless Specialties types (baffled vs. ceramic) against open headers on a dyno. For info, his car was equipped with (I believe I recall correctly) a stock dimension 427 running dual Holleys. This gentleman kindly sent me copies of the test run sheets. Bottom line: the delta between the open headers and the ceramic pipes was only a few hp and no difference on noise level, while the difference between the baffled pipes and the open headers was on the order of 45 hp and a noise level difference of about 5 dB. Noise levels were measured at 20 feet from the end of the pipes. My conclusion from his data was that the baffled pipes cost a lot of hp for not a lot of muffling (at least on the big block FE), so I went with the ceramic pipes.
FWIW, the wife and I use ear plugs when we ride. I have always worn ear plugs while flying (going on 30 years in helicopters), and have found that the EAR brand yellow foam plugs seem to work the best.
Some folks drink from the fountain of knowledge; others just gargle.
Yesterday's flower children are today's blooming idiots.
