Old 10-09-2002, 09:06 AM
wadesdad wadesdad is offline
Cobra Make, Engine: Former owner of an A&C
I ran into a similar situation with my A&C. My mounts were 3/4" off on both sides. I made spacer blocks from a scrap 3/4" piece of steel to fill the voids.
Before you land on a solution see where you'd like to place the engine - centered or offset. It is not uncommon in hotrods for engines to sit slightly to the passenger side to offset driver weight and/or to provide room for the steering column.
I chose centered, however.
Good luck.
