Old 10-09-2002, 11:53 AM
Wayne Maybury's Avatar
Wayne Maybury Wayne Maybury is offline
Canadian Gashole
Cobra Make, Engine: Johnex 427 S/C, 351W, 472 HP, 444 lbs. torque
Blake
Fooling around with a complete engine isn't all that easy. If you are going to have to play with this quite a bit, I suggest that you get hold of a scrap engine block and use it to do all of your trial fitting. I bolted the bell housing to a scrap engine block and put that in the car. I then bolted the tranny to it to make sure that everything fit correctly. You could even put heads on if you wanted.
I found that this worked very well.
Wayne
Don't get caught dead, sitting on your seat belt.
