So far, the best off-the-shelf is the Carerra coil-over setup. RCC offers the best direct bolt in for the CR front suspension. Lower shock mount is below lower control arm centerline for better suspension travel. Handy jacking point also. RCC includes shock upper extention for mating to CR upper shock mount. Nice setup, and it works.
Still pursuing Koni front coilover shock to replace Carerra.
Will pull front suspension apart this winter and work with Koni Tech Support for modified MII coil-over shock replacement for Carerras. Koni's are admittedly a little pricey, but they last the life of the car so you only have to install them once.
