Mick,
Compared to the Jag, our hub carrier is almost an inch longer from the axle centerline to the lower pivot, and more than an inch wider at the wishbone mount. It's not built to take the stresses from a bottom-only mount. No room for tapered roller bearings either. You might check out
Accurate Machine Products for a direct replacement.
