You have a choice here, either go for the correct, most efficient method of balancing a wheel/tire or go for looks. The correct method is to place the weights at the outermost edges of the wheel inside AND outside. This is the high-performance method which should be used on a high-performance car such as the Cobra. Check out a professionally prepared race car. Or, place the weight that would have otherwise been on the outside edge behind the center section. Trouble here is the weight must be much heavier that it would've at the outside edge because of the reduced cantilever effect due to wheel width and it's closer proximity to the rotating center of the wheel . . . a big problem with the narrower front wheel as you've indicated.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
