Old 10-12-2002, 05:47 AM
kountzecobra's Avatar
kountzecobra kountzecobra is offline
I recently installed a dual quad setup on my 351 Cleveland. I fabricated the intake myself from an Offy 360 single 4. Adapter plates were not available for my engine. I wasn't sure it would work, but the results have been great. I use 390cfm Holleys (Turned around backwards) with vacuum secondaries, with the linkage from a 427 Med Riser. In my case, everything fit perfectly. I also had to go with a standard size dist. cap for clearance. I think these carbs would work well in your application also. Drivability is Great! Looks are even better! You can see pictures in my gallery. It was a lot of work, but worth it. Let me know if I can give you more info. Later, David Shelton.
