Old 10-13-2002, 06:29 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
I combined (butchered) the OEM CR heater/defroster with a Vintage Air unit that works.
VA blower and core in modified CR enclosure above passenger side footwell behind WSW motor. Plywood air box to modified CR air distribution box centered on trans tunnel. (Plywood air box for AC evap coil should I attempt AC install later)
Works surprisingly well, but disproportionate with time required to modify.
