OK, I’ve got to share this with you guys and gals. My EM also has a slight shake at 60 to 65 MPH. While I am determined to smooth it out, it doesn’t have to be perfect but smoother. This weekend, I get under the car and find two worn out stabilizer bar bushings and a loose strut rod bushing. Replace the bushings and tighten the strut rod. Now it’s more prevalent!
Next is the tires rebalanced / trued at a tire shop that uses the Hunter 9700 and see it this works. If that doesn’t improve the ride, the power steering unit is next.
Hector Collado
Everyday is a Holiday ... every meal is a banquet.
