Old 10-14-2002, 08:21 PM
Aussie Mike's Avatar
Aussie Mike Aussie Mike is offline
DV,
Coming from you I'll take that as a real compliment.
Mr Fixit Infered that it could be a popular mod in the US. I'll be quite happy to do local gear boxes and if I guess if people want to send me the parts I could do it as well. The only problem with sending me the parts is it still needs a fair bit of dissasembly/assembly on the box.
I know you probably use these T56 boxes regularly behind the Viper V10s in your cars. If you like I can send some larger more detailed pics of what I did so you can do your own. It's not that difficult to do the mod, just a bit fiddly and you will need a mill for some of it.
Ed, you can Email me @ lm.murphy@bigpond.com
Jim,
I suspect the Richmond Box will end up being wider than the T56. My reasoning is that the T56 is a single rail design with the shift rail running down the top of the box. The Richmond box has an external shifter mechanism that hangs off the side of the box and will add to the width.
Mike Murphy
Melbourne Australia
