Old 10-15-2002, 03:37 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
Check for volts on the brake light circuit from the fusebox back. Check both sides of the fuse holder, then at each connector from there back. Make sure the brake switch is adjusted right too.
