Old 10-16-2002, 09:04 AM
coyled coyled is offline
John, try adding a few quarts of oil. If this solves the problem, the pick up is running dry with the normal amount of oil. You may want to run an accusump. I run an external oil pump, an accusump, and had to install drain lines(dash 16) from the valve covers(front) to the oil pan as there was oil trapped at the top of the motor. scott
