You didn't put the wheels on and test fit everything before paint? I would try raising the front end a bit first, by adjusting the coilover shocks so the whole front end sits higher. What about smaller tires on the front. Is the offset on the wheels correct, or are the fronts sticking out too far? The last thing I would do is body mods, and only after everything else failed to work satisfactory.
