You can also use an OEM Corvette trunk prop from a 60's or 70's vette. Not too expensive and works well. They're the slide and latch type. When you lift up, it stays where its put and to lower just raise it a fraction and down it goes. Simple to install too.
Good part is that it looks factory. Had one in mine.
Al
"If some is good, more is better.
And too much is just enough."
--Carroll Shelby
