Old 10-18-2002, 06:19 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Starting from scratch, use the complete MSD setup; distributor, box, wires, coil.
That being said, if you have a new Duraspark setup, and it's working OK, leave it alone, and spend your money on other performance enhancers.
Simply swapping out a Duraspark for an MSD will not result in any performance improvements unless the Duraspark is not functioning properly, or not dialed in. If you do install the MSD, it will need to be set up properly, and dialed in, and there are some tricks to this that MSD won't tell you.
