Did you wire it up per MDS's instructions? I'm using the same set-up, except I'm using an Accel coil. I'm not using a ballast resistor. I wired per their instructions and it works perfect.
BTW, my tach is not hooked to the coil. It's wired directly to the MSD module.
David
http://members3.clubphoto.com/david251117/guest-1.phtml
