Old 10-20-2002, 05:06 PM
Jim Werth Jim Werth is offline
Cobra Make, Engine: B+B 351w #112
If your refering to the lower hose, I used the short hose (part number from B+B) on the radiator and used a coat hanger to figure out the bend for the steel pipe that goes under the crossmember. Took the coat hanger to a local muffler shop and had one bent up for $5. Use a 6- 8 inch staight hose to connect up to the water pump. Hope that helps. Jim
