Old 10-20-2002, 06:49 PM
SSSnake's Avatar
SSSnake SSSnake is offline
Cobra Make, Engine: ERA FIA #2078. 331 stroker, sportsman block built by Evanuik Performance. 450hp
Send a message via AIM to SSSnake
Default Got the fuel pump mounted
This took two nights to put together. Holley blue pump and a fram hpg1 fuel filter. It is 3/8 aluminum bolted into nut-serts in the frame. The pump is wired into the harness and all of the hoses are connected. The only problem now is the battery box cover on the other side can't even compare to this piece
Glenn
