The hex on the
oil pump shaft probably isn't lined up perfectly. Usually you can bump the starter and the distributor will fall the rest of the way in. Also, you can take a long screwdriver and turn the
oil pump shaft through the dist. hole until everything lines up. No machine work should be required.
