Thread: Charging issues
Old 10-22-2002, 10:11 AM
wilf leek's Avatar
wilf leek wilf leek is offline
Cobra Make, Engine: Crendon, windsor 408 stroker, tremec. Also GSX008
65 Amp alternator should cope easily with your load, it does for me.
I suspect it is not charging properly - could be a diode or two out, maybe worn slipring brushes etc.
Do you get 14.3Volts across the battery (most elec loads off, engine running above tickover)? that's the voltage you want to see, it means things are charging nicely.
HTH
Wilf
