Right on Tim. Be sure to put a coil in the lines just below the MC when you install. Helps with air in the lines. You can and should also bleed the MC/reservoir line before hooking it up to the main brake lines.
Al
"If some is good, more is better.
And too much is just enough."
--Carroll Shelby
